suffolk punch 35s ht lead
vanjim50
I would like to replace the HT lead on a Punch 35s.My problem is how do i remove the lead from the magneto?.There doesn't appear to be any screws etc to undo,leading me to think it "just pulls out"Is there some sort of connector that i should transfer to the new lead?.I don't want to proceed if there is any doubt about fitting a replacement.
Many thanks.
suffolk
Once again,many thanks for your encyclopedic knowledge Wristpin.
Suffolk
On some coils the lead was bonded into the coil body but often it is just screwed in. The recess in the coil has a taper threaded screw set inside it and the HT lead is pressed onto it and then twisted in a clockwise direction until it is drawn in and bottoms in the recess. To remove the old lead just unscrew it.
If yours is a bonded one and the lead is damaged you can cut it just below the damaged section, solder a new piece of lead to it , then apply some epoxy such as Araldite around the joint and finish off with a length of heat shrink tubing.
