Suffolk Super Punch 17" Restoration advice
Good afternoon, I am wondering if you might be able to help me with regards to restoration of this wonderful machine. It is my first attempt .
For a number of years I have been tinkering about with this old Suffolk Super Punch 17 ( I think it is, pictures attached ). I would be interested if anyone could help me with dating the machine or any history you might be able to throw my way
It worked a treat when I bought it if not a bit throaty sounding as I think it was described to me. It was very loud but cut and worked quite satisfactorily. I bought it from a farm local to the Shropshire area and the man i bought it off had quite a few of them . this was pre lock down so that gives you an idea how long I have been trying!
I thought I could take it apart which I did and I have successfully bought numerous replacement parts for it including , all new gaskets, new exhaust pipe and cowl and new pull start unit off ebay. I have cleaned all the internal and external parts of the engine and thoroughly pleased with myself I got to the point of starting it up and it does not work.
I think in all honesty I have reached the limit of my knowledge and I think what the problem is now is setting the mower up to have the correct fuel / air mixture or even getting it to pull fuel through the carburettor to ignition. So i have admitted defeat and had to call in the help of a professional and have taken it to a local lawnmower repair shop who said it might be something to do with timing issue. I wonder if anyone has any expanded knowledge on what this means.
I have attached some pictures so you can see my attempts (or have a good laugh) and if anyone has any advice for a complete novice who was and still is obsessed by lawnmowers from a very early age. I would also be interested in what to do next once it is running. How do people go about painting them and what is the process?
Any help would be gratefully received.
Yours sincerely
James Peacock
