New (to me) 14" lightweight
Hi all
Time for a new project. This is my first powered cylinder mower and my lack of small engin knowledge is showing.
Two issues and two general questions.
Issue1: engine only run on full choke. The moment i barely crack the choke it stalls. I cleaned the carbi (it was filthy inside). No change to performance. I did notice the long brass piece in the carbi was very tight and had to be coersed to get down ito the correct position but i got it in. can't imagine this is the issue
Issue2: engine wont shut off even when throtle lever is all the way to the right.
Question 1: ive read elsewhere that modern 2 stroke oils are such that you should run your mix leaner than 25:1
Question 2: After removing the rust from the cooling fins, what do the cool kids apply to stop rust reforming? I was thinking fish oil or bluing solution.
