Webb 2 Speed Transfers
Hi folks
Thought you might like to see my Webb 2 Speed now it has the chain cover transfers that were obtained through the OLMC Shop, BIG THANKS Colin !! A grass box transfer was also supplied by Colin which finishes off the job off nicely. Cheers. Rob
Rob, Did you remove the 2…
Rob,
Did you remove the 2 ball bearing blocks at each end of the cutting cylinder, when you restored it ?
If so , how ?
Hi Moorcroftman. I did'nt…
Hi Moorcroftman. I did'nt sorry, so cannot help you. After I acquired the mower it was found to be in need of a new cutting cylinder which was obtained for me by John Gregory at the Old Lawnmower Company from Garfitts in Sheffield. John also fitted the new cylinder as he was overhauling the mower for me at the time. Cheers. Rob
Thank you Rob for your kind…
Thank you Rob for your kind comments. An interesting exercise I hope you would agree and not too onerous.
Thanks are also due to our printer/supplier Titch at Machinery Decals. Without his enthusiasm and skill we simply would not be able to provide this service to Club Members.
This gives me a good opportunity to promote the Club Shop and point out that we have approaching 100 transfers available. In some cases this is the only source that I am aware of. In addition we are able to create new designs provided we have good enough information to work from.
See the whole range on the Club website : https://oldlawnmowerclub.co.uk/restore/transfers
