Webb wasp ball bearings
Any advice please ? All appears to continue to work but bits have been removed. Ball bearings not coming out although some are missing.
Looks like bearing braking…
Looks like bearing braking up, suggest replacing if cost effective. Simply Bearings?
Thanks both, I've ordered…
Thanks both,
I've ordered one 16 inner 40 outer 12 width/ depth...may fit , may not £10.
Any thoughts on where to get a RS5 ?
None on Ebay.
These will be a standard…
These will be a standard size bearing - not proprietary to the mower - and should be readily available. Bear in mind too that they will almost certainly be Imperial dimensions.
I have in the past bought Imperial bearings from suppliers including Simply Bearings (mentioned in a previous response) and Wych Bearings which is currently listing the RLS5 at £3.52 ex VAT for the open version and £3.81 ex VAT for the enclosed version. Both would be OK for your machine I would expect.
Very clear advice. Thankyou…
Very clear advice. Thankyou so much. I have ordered one from Wych.
I just need a couple of Ransome carriages now ( for less than £25 on ebay !)
I have used Aruldite to repair mine, broken in a vice when straightening ! I don't know if that is strong enough.
Thankyou for that. Just…
Thankyou for that. Just ordered from Wych
Please let me know how you…
Please let me know how you get on with finding Ransome carriages for £25. I had to pay in excess of £100 each for the couple I’ve got for my marquises . Maybe I’m looking in the wrong places lol.
Simply Bearings SKF RL5 £7+…
Simply Bearings SKF RL5 £7+. ea. correct quality self aligning bearing.
RLS5, single line rigid £5.42 +or £5.54 +shielded.
What are Carriages, not a term that I’m familiar with ?
Hi Angus. I wonder if a …
Hi Angus. I wonder if a 'Carriage' is the 2 wheeled frame for moving the mower over rough surfaces? Photo shows a JP Carrier. Maybe??
Cheers.
Rob
Understood. Would probably…
Understood. Would probably understood earlier had it not suddenly cropped up in a thread about bearings!
Understood. Would probably have understood sooner had it not popped up in a thread about bearings !
These are listed as'…
These are listed as' carriages' on the Webb parts manual
Ah got it, you are talking…
Ah got it, you are talking about Front Roller Brackets for an Ajax???
Yes they are called carriages on parts list but probably never referred to in that way in modern times!
Out of interest the wheeled carriage for the Webb is actually referred to as a 'transporter'.
It may be helpful in future to supply images they speak a thousand words!
Looks like it’s been rather…
Looks like it’s been rather hot. No option but to replace it. Those RL5s are getting expensive , try Simply Bearings , they may give an option of an economy one.
