Dating an Atco Deluxe 14
Hello, I have a Atco Deluxe 14" mower. How do I date it? There is a tag with B23. The Engine # A8929 / 1 . The backslash is not clear. The fuel tank has a plastic fuel tap.
I am taking it to a British Car club show at the weekend at Fort Langley. British Columbia, Canada and would like to give it a date.
The picture of the mower on
The picture of the mower on the parts list brochure shows the same mower as mine. I will take some photos tonight and post.
Is there a serial number on
Is there a serial number on the mower that I should be looking for?
I don’t recollect Atco making
I don’t recollect Atco making much reference to serial numbers other than on Service Bulletins when defining when modifications were required or there was a minor design change.
Here are the photos
Here are the photos
Here are the photos
Here are the photos
I have a 12" atco deluxe with
I have a 12" atco deluxe with a small number tag on the body.It was partly hidden and not seen until the engine was removed because it is painted green like the whole mower.I am guessing it to be a cheeper version of the brass tag witch was on the side of the older machines.mine is stamped A12 1267
Sound like yours was built in
Sound like yours was built in 1967. Mine only has B23 stamped on the tag, which is located on the deck under the engine cowling.
Images of the mower may help
Images of the mower may help if we are unable to ID from serial numbers
