Harry rotary mower
8 posts / 0 new
philip-s
Last seen: 1 month 1 week ago
Harry rotary mower
Does anyone recognise this make of mower? It has an aluminium body and a 5hp Briggs engine and the only name on it is HARRY cast into the body.
Last seen: 9 hours 47 min ago
Assume its made by Harry in
Assume its made by Harry in Japan, they make all sorts of garden machinery, use google it will throw up lots of information.
Also https://www.harrymowers.co.uk/
Last seen: 4 hours 49 min ago
For once Clive is wide of the
For once Clive is wide of the mark!
Harrys were made in Italy and were  distributed by EP Barrus of Bicester as Lawnflites.  Latterly by Irish Farm and Garden from Dublin , aka FGM Claymore of Bedford on Avon.
I sold dozens of them.
Looks like it’s been modified for gassing moles or rodents.
Sorry about that Angus did
Sorry about that Angus did only get a low grade for my CSE in geography, or was I thinking of Arry! good to have you covering the rear (:
philip-s
Thanks, yes someone else
Thanks, yes someone else suggested it was for gassing moles. Any idea of the mower's age as it has a cast aluminium body, unlike the thin iron of modern mowers. I wonder who came up with the name Harry.
Quality machines tended to
Quality machines tended to have cast alloy decks as they were more resistant to corrosion than pressed steel but in rough use could be damaged from impact. Some machines intended for commercial use have a steel liner within the alloy shell.
The Italian manufacturing company was originally called SIAG which, I’m guessing , were the initials of a four word company name, as in FIAT. Later it was known as Harry SPA.
As far as dating goes. In the absence of any Harry identification plate your best bet is the Briggs and Stratton engine Model, Type And Code Numbers embossed into the engine cowling - probably above the spark plug. The Code Number is the date of manufacturer, the first two digits being the year. Assuming that the engine is the original, it’s fairly safe to assume that it was fitted within six months.
Edited  to correct senior moment. Perhaps no one noticed!
Last seen: 1 day 13 hours ago
Wasn't there a problem over
Wasn't there a problem over the later HARRY mowers ? FMG not actually owning the name or the right to use the name ?
PS, what are 'who digits' ?
I meant Two and you meant FGM
I meant Two and you meant FGM !!
Not aware of an issue over the ownership of the Harry name but unless it was a Hayter or a Mountfield one would sometimes struggle with a potential buyer.
