Atco lightweight kickstart
I have recently acquired an Atco lightweight,I’ve done a bit of research on the club library pages and come across a brochure for 1939 and noticed that the fuel tank mountings are different to mine,does that mean is probably older than 1939?
also the kickstart return spring obviously isn’t right.Does anyone know what should be like please
Clive1997 Sun, 30/07/2023
Hello
Re the date you could well be right that its a bit earlier, the image below is similar to yours & from the 1937 brochure, sorry don't have any close-ups of the spring mechanism, but I'm sure some others out there will have.
Looks in very good used condition with plenty of original colour, transfers etc, hope you will be just giving it a good clean and wipe over to preserve its as found looks.
Do you have a grass box?
1manwent2 Tue, 01/08/2023
Thanks for that Clive,it does have a grassbox with it which is an extra bonus and no I don’t intend to go anywhere near an aerosol can with this one
arnk Sun, 24/12/2023
Here are some pics of my 1936 20" Atco heavyweight - the fuel tank supports are like the brochure.
I am not sure if the spring is original.
Al
Atco 20" with 2 stroke Villiers 147cc 1.5 hp.
Kickstart
