Engine Chain Sprocket Atco Standard 16"
3 posts / 0 new
TrevL4
Last seen: 2 weeks 5 days ago
Hi, I'm new to the club and have purchased a Standard 16" mower that has stood for about 15 years, the engine was seized so decided to remove it, when I removed the fan, drive chain and sprocket I noticed that the teeth on the sprocket were damaged and a couple missing altogether. I have tried to buy a sprocket but cannot find anyone who has what I want as it is 38.2mm long with a c/bore at the sprocket side and a tapered bore to mount on the shaft, can anyone tell where I can purchase on as I have ran out of places to contact now. The next best alternative is to buy a triplex sprocket and machine two rings of teeth off and machine the bore to suit
DJD
Online
Last seen: 7 min 52 sec ago
There are places that are
There are places that are willing to make motorcycle one off sprockets to suit any chain, so I can't see why they wouldn't make a mower exception. Talon Sprockets is one I've heard of, but not dealt with, surf the 'net and see, is my advice.
TrevL4
I have surfed the net for the
I have surfed the net for the last six or so weeks and found nothing near, all the sprockets advertised are nor the same as mine. I thought I may be able to buy a second hand one from someone rather than have friend machine a triplex sprocket which is 50mm long as he is a bit busy making sure his Showman's Traction engine is ready to run later this year. But thanks for the advice.
