Front Rollers wanted, Webb 14" petrol mower
Brian Latham
Could any member point me to a source to obtain replacement new rollers with the following dimensions?
External diameter 65mm
Internal diameter 17mm
Required Length 3 at 100mm, and 2 at 50mm
Many thanks
Mower Front Rollers
Thanks Ray
I have now been recommended to Southport Lawnmower Museum, 01704 501336. They say they will obtain the rollers for me.
Brian
Mower Front Rollers
Brian,
That's ok, I imagine that coming from there the rollers should be spot on if the restorations on their website are anything to go by.
Ray
Webb Front Rollers
Hello re the new rollers for your Webb mower you may try searching your area for someone who has a woodturning lathe who may be prepared to make them for you as a project in return for suitable remuneration. Hopefully other members reading this may know of an alternative source and post directions also.
Ray.
