New member with an atco 16" standard.
Hi all, I have just acquired a atco 16" standard 1923/1926 which i intend to restore, I will try and upload a picture if i can work it all out. plenty of questions to come.
Clive1997 Tue, 20/11/2012
There are some notes on the forum about this, but I would be happy to help out if you want to e.mail them to me & I will put on for you.
e.mail  clive@adurgardening.com
Clive
cheyenne Fri, 14/12/2012
Hi, Would anyone know the right shade of green to use on a atco standard ?.
many thanks..
Clive1997 Fri, 14/12/2012
Hi there
The paint colour recommended  is S5040G30Y, local paint specialist should understand this code& be able to mix for you. Shades often varied when mowers were made/seviced, sometimes just using the nearest available tin of green paint.
I tend to find an area of frame etc that has been concealed away from light,oil etc & take this along to a paint supplier that has one of those magic scanners that can pull up a direct match which they can mix for you.
Take a look at my website & you will see the result of doing this (note the images were taken in different light, the later ones with the wooden rollers/handles are how it actually looks in daylight.
http://www.vintagemowers.co.uk/page3.php
Hope thats of use.
Clive
cheyenne Sat, 15/12/2012
Thanks for that clive , Thats a great help, i will now look into it...
cheyenne Mon, 22/04/2013
This is how far i have got with the atco standard, hope to have it finished for the annual rally at milton keynes in may.....smiley
Clive1997 Mon, 22/04/2013
Hello again
Looks good be interested to see at MK, I have a couple of standards but not restored any yet, they are a bit down the prority list, but I do have one that operste o.k. Did you have a box?
Cheers
Clive
Hello clive,
Yes i do have the grass box  i sprayed it at the weekend, so waitng for the paint to cure...
All the best kevin...
Sorry Kevin,
Silly question, has been a long day today, but it was obvious you had one from the previous images!
Off to the pub now to revitalise my braincells.
Clive
Denham2013 Tue, 21/05/2013
thanks cheyenne for sharing your experience and pic to all.nice job. keep in touch.
