The First Cut of The Season !
Longer term Club Members will no doubt recall our late Chairman Tony Hopwood had a tradition of mowing on New Years Day with his early Dennis. Inspired partly by that, but also by the plain fact that I've been wanting to catch up with some mowing for a while, I took the opportunity of having a go today. Sadly grass and ground conditions precluded the use of a proper lawnmower so I had to resort to one of my ever reliable and forgiving Honda's.
This currently somewhat grubby example is an HR 2160 from 1992. Being only thirty years old it is not by my definition an old lawnmower so might be considered something of an imposter on this website. In fact Club Member Brian Radam of the British Lawnmower Museum would not class it as a lawnmower at all, merely a grasscutter. Too many wheels, too much plastic and only one blade. It is however a very good machine and one that I would recommend for early and late in the season when a proper lawnmower is less practical. ' The Season ' is of course these days much longer than it was historically, no doubt due, at least in part, to climate change.
I would not necessarily recommend mowing at this time of year; one needs the right conditions, and machine. The situation I have here though almost demands some winter mowing. If I were to leave it until the Spring the grass would be calf high and consequently more difficult to get on top of. Gardeners amongst you will observe that this is not a lawn situation, neither is it ever likely to be, rough grass is the order of the day. This area has been informally laid out for at least 130 years and the grass is very unlikely to have ever been properly levelled, prepared or laid. There is evidence of some sort of path surface under the grass, leading up to the front door. At this time of year we don't worry about neat edges, the object of the exercise is to remove the bulk. Edges are kept trimmed when the borders are looking at their best - if time permits !
Today has been the first day…
Today has been the first day this year I have got the mower out.
Albeit cutting the moss, and debris next to the hedges where Blackbirds have been scratching around.
I have been careful to avoid the dafodills and snowdrops coming up.
Firstly I just used my 17" Badge Engineered Hayter of 1997, as this was first to hand, then when this left most of the debris, I used our Hayter Harrier 56 Auto-drive of 1991 (Bought Second hand in 2001, fitted with replacement deck of 1997, about 10 years ago) This has picked most of the debris up and rolled any lifting turf.
Hadn't done any gardening or mower matters since the end of November due to C19!
Hi folks. I could'nt wait…
Hi folks. I could'nt wait any longer to get behind a mower again! First cut last Sunday with my Green's Monitor Mk 1 and second cut today with my Green's Monitor Mk 2. Pleased with the results the Monitor gives. Top Dressing and an overseed in March so the mowers have something half decent to have a go at. Cheers. Rob
I can remember those first…
I can remember those first cut events from the days of the original OLC Forum,
Am I correct in thinking that there was a club member from Australia or maybe New Zealand who managed to cut grass in the early hours of the first day of the year.
Our little patch of grass had a trim just before Christmas on a rare drying day but since then it has been far too wet even for our old electric Flymo E30 that is around the same vintage as your beloved Honda and still going strong.
