How do you remove the Extension Cylinder Spindle
sam.baker107
Hi all,
I have hit a snag in my restoration project of my Ransomes 20" Auto Certes MK2.
I am trying to remove the Extension Cylinder Spindle (MBA 4958) from the cutting cylinder however I am unsure if it is threaded or just needs tapping off?
Can anyone help?
Hi, Welcome to the Old Lawnmower Club. The Auto Certes extension spindle is I am sure screwed on to the end of the cylinder with a left handed thread. If you lock the cylinder with a piece of wood you then can either tap the the spline with a brass drift or use a chain wrench around the extension piece to slacken the thread in a clockwise direction. This is assuming that you have already removed the locking screw (also a L/H thread) and dog clutch assembly. Ray.
