Ransomes Ajax mk5 cylinder bearing felt washers
Hi all,
I am a new club member and am renovating an Ajax Mk5. I have stripped it down and replaced the cylinder bearings.
I need to source the two felt washers in that go in the bearing case.
I have searched on the forums and online but can't source any?
Is there a club member who can help?
Thanks in advance
I think that they are the…
I think that they are the same as used on older Marquises etc. If so , readily available from Ransomes’ agents.
Several changes of part number over the years, now 650000192.
Thanks, I ordered some. Here…
Thanks,
I ordered some.
Here are the photos of the cleaned and replaced cylinder bearings and gears.
Next job will be to prime and paint.
All clean and ready for…
All clean and ready for assembly and you’ve got the correct oil gun, Ransomes have always recommended oiling, not greasing . Something that I always do is to soak the new felts in oil before assembly so that they are completely saturated. Gives them a good start and prevents any pick up on the shaft .
Thank you for the advice …
Thank you for the advice @wristpin, I'll post some progress photos when I have them.
Hi, I've lost the photo I…
I've lost the photo I took before dismantling the bearing.
Is the correct order
Felt washer, metal disc, bearing, dust cap?
Thanks.
Metal disc next to the…
Metal disc next to the bearing, then the felt, then the cap.
Try ramgaskets.com
Try ramgaskets.com
