Springs and things
Kormaboy
Hi all
I have a 24inch Web sit on from the 80's I am restoring and wondered where I might source some springs there's a couple that are broken so need to replace them?
many thanks
Time wasters and tyre…
Time wasters and tyre kickers come to mind 🤭
One of them is the spring…
One of them is the spring that tensions the clutch arrangement. The other is a much smaller one that goes somewhere on the carb (not sure where yet)? You can see it at the bottom of this picture
Presumably the tensile…
Presumably the tensile spring that put pressure on the two v-belts under the side cover?
Governor springs on the engine?
Spring that goes under the handlebar slide adjuster lever?
Springs under the seat?
