Atco 1247 full nut & bolt restoration
Hi all
thought i would post you all a few images of my just restored Atco 1247 lightweight.
a few then & now images if you like.
just goes to show I think what can be achieved with a little hard work & effort.
im glad to bring this one back to life although it is only intended for display never to be used.
a true full nut & bolt restoration anything that needed replacing has been done, carburettor, flywheel, magneto,coil.
literally every single nut & bolt.
took about 4 months from start to finish.
i hope you enjoy the images (the colour looks a little dodgy on one image it’s just the lighting)
by all means let me know what you think.
regards
Martin.
gtc Mon, 03/06/2019
Immaculate restoration. Not sure about the Villiers and Pugh decals. Were they standard in the UK?
That's the first 12 inch I've ever seen with a dog clutch on the roller. Speaking from experience of mowing a lawn studded with trees in raised beds with a 14 inch Atco it was a very useful feature.
Although you say it will be display only, have you actually started it to see if it will run?
Martin1972 Mon, 03/06/2019
Hello
yes, it runs & starts very well.
The villiers & Charles h Pugh decals are the only two non standard additions I decided to make.
As it is only a display restoration I just wanted to make a more notable reference to the engine maker (villiers) & of course manufacturer (CHP), just for display purposes.
everything else including nuts,bolts & washers have either been cleaned of rust then machine polished or just generally cleaned where needed.
regards
Martin
Antbr123 Mon, 03/06/2019
I concur with GTC.  Very nice restoration indeed and thanks for posting.  Bu now the big question....what next?
regards
Chris G Mon, 03/06/2019
Stunning job, thought you had replaced the fastners with stainless until I re-read. High polish will keep the rust gremlins away for sure, it is quite cheap to get batches of fastners zinc plated also. The original front roller looks great.
I have never seen such a pristine shed either :-)
Top job!
Good evening & thank you for your comments.
i have really enjoyed this particular restoration, although testing at times.
with regards to what is next? I’m none too sure yet, it really depends if I could possibly sneak another project in to the shed whilst my partner is not around.
regards
martin
Buryan Thu, 25/07/2019
Love the roller - looks as if it will double as a pastry chef's tool - -
As a matter of interest and never having bought a new mower in my life!, how are nuts and bolts etc. generally treated by a manufacturer - painted or zinc coated?  How were they presented in the good old days of my newly acquired 2-wheeled Atco Scythe?  Any ideas, please?!
k.runcimanannand@gmail.com
Update - just noticed the beautifully presented fly-wheel.  Martin, did you coat the metal of this and the fixings with a lacquer or some other preservative, please?
