FOLBATE J1 refurb.
This is not a restoration because:
a) I did not like the original shade of green.
b) It is not rare and therefore worthy of restoring to original.
c) I wanted to do my own thing with it anyway.
d) I had an unopened tin of a 'quite nice' colour Hammerite Smooth.
Before and after pictures:  The bottom blade needs to be replaced.  I have some steel sheet of the right thickness to make one but have, as yet, been unable to remove the retaining screws.  A job for later. The 'new' rear roller has been temporarily borrowed from my similar Suffolk Sidewheel
Harvey
 r
hdtrust Sun, 11/02/2018
Well done I like it!
Just one thing is it going to be an ornament or a useful asset to cut grass, because if its the latter, you need to remove the paint from the wheel grips, as she will slide on the lawn!
Harvey Mon, 12/02/2018
Thanks HD,
Good point about the wheel grips although they were originally painted but I guess the Hammerite could be a bit slippery.
No, not intended for use. I don't really like sidewheels ....( this is actually my wife's mower ) I have a selection of hand / push 'roller' mowers for cutting the lawn.
Harvey
