Hi Everybody
Hello All, just thought it would be polite to introduce myself, I usually frequent motorcycle related forums as my main interest is in restoring and building motorcycle, but I may have caught the Lawnmower Bug.
I recently decided to replace my clapped out Flymo as it has given up the ghost and while searching for a replacement I came a cross an old Webb Battery Electric De Lux 14" on eBay and I thought it was worth a punt.
I must say I've not been disappointed, just gave it a clean, oiled the chains, replaced the rollers with a couple of drilled out rolling pins and put a new battery on it and bingo a smashing lawnmower for less the cost of a half decent new one and cyclinder mower to boot.
I'll have a few more questions to ask a little later but for now I would be interest to know its age.
Cheers
J
Thanks Clive,
Thanks Clive,
The sticker on the back says 254, so I guess it was born around the time I was then,
That's good, looks like they
That's good, looks like they continued to 1971 when superseded by a belt drive model No. 296 which was fitted with a quickly removable cutting cylinder & single 60amp/hour battery. I have dug out the instructions for your model, bit moth eaten & chewed like us all!! but readable.
Hello & welcome to the forum
Hello & welcome to the forum as to date depends which model but some guidelines below...
Model all 14in De-Luxe
206 1960 CAV Motor
215 1961 Lucas Motor
218 1962
235 1963
247 1964 Lucas/Siba Motor
254 1965 2 speed Siba Motor
I'm not sure where the model number was???
Hope that helps, you now need to collect the whole set, there are about 20 different Webb Battery models !!!!
