Jap 2a
Hi guys I'm a new member, looking for bit of advice, I'm restoring a Jap 2a, was wondering how you adjust the taps for valve clearance, when you put the camwheel on it covers the valve stems and can't get at them with feeler gauge
Thanks wrist pin, I also have
Thanks wrist pin, I also have another manual on Jap engines and doesn't seem to mention on the rebuild part either! I'm think of just putting to TDC with cam in, then trying to remove again without disturbing the valve lifters, there very indented, don't know if it's just wear, but I think she's been past around abit and had a few bad restoration jobs, when removing the valves the inlet looked as if someone had just ground them in! Exhaust was opposite as if it was never touched!
You wouldn't know who's best
You wouldn't know who's best for spares for these little engines? I'm looking 2x crankshaft bearings and could shells for big end. Also have another two stroke on a Ransomes spirit probably need bits for, pics to follow for this
I've no experience of the Jap
I've no experience of the Jap 2a, and know there are exceptions like Briggs & Stratton's "easy spin," but most single cylinder engines are "off the cam" when both lobes point downwards like an upturned V, so if you put the cam in like this, then set clearances, they should be right. Usually the keyway is either at the top or bottom when they are at this point too.
Think that your best chance
Think that your best chance for parts and info is Meetens
Cheers guys
Cheers guys
This may be of future
This may be of future interest but does not seem to include any specific reference to any special procedure for setting the valve clearances.
https://www.dropbox.com/s/0x2o2jr8u1xwhno/JAP%20Model%202A%20Industrial…
