Suffolk Punch Dual Drive mk. 7
OLC Shop
If anyone has original chaincase and/or grassbox transfers in situ on a Suffolk Punch Dual Drive mk. 7 would they please let me have the measurements - width and height.
It's this one :
Thanks in anticipation,
Colin
Thank you for confirming that
Thank you for confirming that. I suspect the slight differences reflect the two being printed at differeent times or different sources. Research has revealed that the transfers should be slightly different in design - it's all down to the hole for the bolt in the chaincase !
We should be taking delivery of updated sets for this model shortly.
Colin
The chaincase one is 224mm
The chaincase one is 224mm high x 226 mm wide. The grassbox one is 225mm high and 228 wide. hope this helps
