What on earth is this beast?
No connection, just something I've not seen before.
https://www.ebay.co.uk/i/164406121016?rt=nc&_trkparms=aid%3D1110006%26a…
Messorestore Sat, 03/10/2020
It must be a JP super. I've included photos of my JP Super electric. If you look at the side frames they are exactly the same. Hope I'm right. Thanks Sean
Adrian Sat, 03/10/2020
Thank you all, still a fairly bizarre looking machine even without the funky camera angles of the ebay ad!
Henry Ellis Sun, 04/10/2020
It is an early 12" JP Super Electric,made in 1949. It looks as if it has been back to the factory at some time and had a clutch fitted to the rear roller; the switch on the motor is certainly from a later period. Early Super Electrics had a different switch assembly fitted using the 2 holes just above the new clutch housing.. Henry Ellis
