Ajax Mk5 trouble
Cosa200
Hello all.
Picked up off someone’s drive, a free Mk5 mower.
so stripping it to restore it etc.
I’m having trouble getting the small cog out of the case.
is there a special way of doing this please?
Thanks.
Alan
Just pulls off, loads of…
Just pulls off, loads of wd40. But lots of wiggling and very careful levering.
Sometimes the threads have been damaged.
Persistence but care, I'm afraid.
Good luck
David
Having trouble ? Do you mean…
Having trouble ? Do you mean unscrewing it ? Take the other two gear wheels out to make some space. Then get a genuine Jubilee hose clip of right size to clamp around the small gear wheel . I say genuine as there are lots of inferior copies that won’t tighten up properly. With the clip in place and proper tight you can lock the gear and then turn the cutting cylinder with a bar through it and unscrew it.
