Anzani Lawnrider v belts?
Hello all
Im in the process of re-assembling my Lawnrider but I'm a bit perplexed by the new v belts that I need.  The simple question would be does anyone know the spec of the belts needed from refurbing one?  Mine is I think circa 1966 with the two driving wheels and lever to disengage the cutters.  I have the part numbers but I don't think they relate to any sizing.
I've measured as best I can the old ones but I can't seem to find anything that really matches the circumference of the old ones.
ive worked out they are "A" size so 13mm/half inch wide and 8mm/ 0.31 inch deep.
The lengths measured round the outer circumference are 36 3/4" or 933mm, 29.5" or 750mm and 25 5/8" or 650mm give or take.
Any ideas?
Many thanks
