Atco Commodore B14 Mitsubishi G221P-LSA - governor adjustment
philreid@btint…
The governor linkage came loose on the above mower and I cannot find anywhere on the web advising how to adjust it.
Do you lock it in position:
- With the groove in the spindle showing vertical or horizontal?
- With the throttle set to fast or idle?
- With the governor lever being perfectly vertical or what?
Also, how freely should the governor spindle move? Very easily or with a bit of resistance? Mine is the latter.
Can anyone advise on the above - image shown (rotated 90 degrees for some reason?)
Many thanks.
Many thanks - seems to have…
Many thanks - seems to have worked.
Slacken the nut. Move the…
Slacken the nut. Move the arm to full throttle . While holding the arm and throttle fully open turn the slotted shaft in the direction that would give that throttle and arm position and tighten the nut.
