Early Dennis technical help
William Proudfoot
Has anybody got any idea how to remove the sprocket from an 1925 Dennis cylinder? The drive chains are on the inside of the frame so the sprocket is inside the ball bearing. Is there a key of some kind, is there a nut hidden behind the bearing that I can't see. I don't want to just put a hub puller on it if there is a hidden nut. Any thoughts?
Thanks,
William
