Oil gun
moorcroftman
Is the configuration correct ? Any instructions welcomed. Is there meant to be a small hole in body shaft as in photo
Thanks Rob. The other photo…
Thanks Rob.
The other photo was meant to be ' how do I get the ball bearing arm off and on ?
Hi Moorcroftman. I would say…
Hi Moorcroftman. I would say no as the oil/grease will leak out from the main body of the gun. I have a Tecalemit gun, the type as in your photo, but with a different model no that I use on my Ransomes Ajax 5 to oil/grease through the nipples on the machine. I also have a Webb Witch but use a normal oil can to lubricate areas on it. Cheers. Rob
