Ransomes Ajax Mk 3 Wooden Handles
Hi, I'm new to the club and about to start my first restoration of a Ransomes Ajax Mk 3. The wooden handles are in need of a bit of TLC but will certainly be useable. I notice, however, that both handles spin on their fixings. Should they do this or should they be rigidly fixed?
Thanks in anticipation
MikeD Mon, 31/01/2022
hi the handles have to be fixed to stop them from turning.THEY SHOULD BE FITTED WITH COACH BOLTS which have a square at the top and screw into the iron handle or  on later machines have a nut on the end of the bolt.if you do need new handles or rollers contact club member MICHAEL FLOODY who makes excellant rollers /handles in beech oak or even the leg off your table just dont lean on it.i rest my bottom blade.
