Timing disc question
goodgrass
When reading a timing disc for is " before " TDC right of the the TDC center line ?
Thank you for your help -
Thank you for your help - much appreciated.
I printed mine and stuck it on with double sided tape!
Depends on the rotation of
Depends on the rotation of the engine! Most lawnmower / small industrial engines rotate clockwise when viewed fro the magneto or flywheel side so BTDC is to the right of TDC
