Villiers F15 Torque specs
Gnasha
Hello. I am having difficulty with finding the above. I have however found the following specs for a mk12 on this forum.
Can I use these specs for an F15?
Clutch clearance 0.014”
inlet 8thou” and exhaust 12thou”.
Cylinder head 12 lb feet
Big end 8lb ft
Flywheel 30 lb ft
Crankcase end cover 9 lb ft
Thanks for reading.
No but thank you .You gave me
No but thank you .You gave me valve clearances.
Gave you this a while back?
https://www.dropbox.com/s/qbzpnukk2kgc8p5/Villiers%20F150001.pdf?dl=0
