Atco Royale 24" - Retro fitting front roller assembly with rake ?
Hi all,
I have an Atco 24" Royale (I think - Briggs I/C engine) and am wondering if it is possible/relatively easy to retro fit the front roller, incl the rake assembly, to a machine which only has a roller, on the basis that it is presumably better for the lawn and will improve the cut.....?  Would it bolt straight in or would modified/new side plates etc be required....?
Any comments would be very welcome
Many thanks
Richard
wristpin Thu, 16/04/2020
I'm not aware that Atco did a rake for the 24" Royale. I can only find a parts list for the 20" Club
However Allett now manufacture the Royale under the name Buckingham in 20,24 and 30" sizes and show a rake.
The attached illustrated parts  list may be of interest.  ***Oh B****r just remembered that this site wont accept pdf files. Will be back with a Dropbox link in a bit!
EDIT
https://www.dropbox.com/s/rr6tz0i8kku78ur/Allett%20Buckingham%20front%2…
Andrew Pritchard Tue, 06/04/2021
I have the front tine assembly fitted to my 2003 Atco B24. Unfortunately, it has bad corrosion and many of the tines are damaged/broken.
I need the complete assembly really, ie. the frame, shaft and tines.
The parts on the mower magic site do not appear to be available.
Where can I purchase these?
