James Watterson Fri, 05/08/2016 Can you tell me where I can get the paint for this mower, which I understand is Ransomes Green? Also is it possible to get this in 2pac so that I can spray it on. Thanks Forums Technical Talk to an automotive paint wristpin Fri, 05/08/2016 Talk to an automotive paint supplier but don't even consider spraying an isocyanate based two pack with out a fully air fed mask . It takes only a little exposure to leave you with occupational asthma for the rest of a short life. Read up on it. http://www.hse.gov.uk/pubns/indg388.pdf
