RSJ Ajax Mlll
Malcolm Hobbs
I am a new member as of 7th May I am trying to keep an Ajax MkIII going but now need knowledge from someone with experience.
I have had the mower apart 5 times 3 times very recently..
This machine has cast iron rollers. The shaft and rollers are separate from the machine. I need to get the right hand (gear end) ratchet/dog drive off the shaft so that I can drill and tap a new Grub screw hole in the hub. Any guidance document or instructions please
Regards Malcolm
