suffolk super punch
7 posts / 0 new
cueball
Last seen: 5 months 3 weeks ago
suffolk super punch
Can my super punch be converted to electronic ignition
DJD
Last seen: 1 day 23 hours ago
Almost any magneto assisted
Almost any magneto assisted engine can be converted to using one of the Atom, Meco or similar units which use a transistor for switching, instead of the points and capacitor. About the only electronic alternative for most I imagine, the Atom unit, from Australia was once very common and popular, I cannot now remember why they were discontinued. But they came in many different versions and colours for different makes and sorts of engines. The majority were for small two strokes, but others existed for four strokes too.
Last seen: 53 min 32 sec ago
So long as your engine has a
So long as your engine has a separate coil and condenser ( capacitior) you can fit either a Meco or Nova trigger module. However later   magnetos used in Suffolks had the condenser embedded within the coil and are not suitable for the conversion.
cueball
can you point me in the right
can you point me in the right direction to purchase said coil.
Cheers
“Said coil” ? With or without embedded condenser?
cueball
Condenser is within the coil
Condenser is within the coil not seperate
As the add on electronic
As the add on electronic trigger modules don’t work with that coil, your probable options are - fit the earlier coil that can be used with a  module, or, fit the later fully electronic coil plus a new flywheel.
In either case talk to George at Villiers Parts.
http://www.villiersparts.co.uk
