Which Briggs and Stratton 60102 Armature-Magneto
doubleg
Hi guys,
I need a new ignition Armature-Magneto for Webb mover with a Briggs and Stratton 60102.
Currently its running point ignition, which I assume will be replaced by the newer electric versions.
Looking at the Briggs and Stratton website the part I require is Part #591420.
Does anyone know if any other units will work?
Thank you!
GG
If you've looked that up
If you've looked that up using the Model, Type and Code numbers from your engine, look no further. If you are handy with a soldering iron you can buy an electronic module to clip to your existing coil and do away with the points and condenser.
